T
The Ghost
So I have used CW1308 0.5mm² over a 25m. run (2 twisted pairs for 3+1 system). The bottom line is the door release (mag lock) does not work. Call and speech works on the handset so at least the person can be called and pick up the hand set and converse. I am 99% certain the wiring is correct and have the videx wiring diagrams which all look correct to their schemata. I am thinking there is ohms or vd problem so not enough voltage gets to release, so ok I use another twisted pair and double up. Anyone got info on vd and or ohms per m. on CW1308?
