Views wanted... | on ElectriciansForums
Discuss Views wanted... in the Australia area at ElectriciansForums.net
Hi guys.
I wonder if I can inquire of your collective knowledge on this one. A colleague passed me a job where the customer had a couple of faults.
One was that kitchen lights would trip the RCD when switched on. The installation is on a 16th edition split board, and none of the lighting circuits are on the RCD.
Interestingly, the trip occurs only first thing in the morning, after which the lights can be switched on and off with no tripping.
I'm scratching my head. I tested the whole house, and found no other clues. What do you think?
Thanks...
Heating circuit has stolen a neutral?
Reply to Views wanted... in the Australia area at ElectriciansForums.net
Did it work?
There should be. Keep them all straight, insert two and then the third - don't twist them all together. If that doesn't work for some reason, use...
