Hi all,
I have a 2019 mercedes vito with SAM fault . No water damage inside, right drl is intermittent . I've powered a relay from the left and taken a supply from the front fuse box to get me through the MOT. Notice voltage at lamp is only 9.5V (same brightness on left), but the relay brings both up to full brightness. Other lights are all effective, but I don't know which is the +VE feed to check due to limited drawings, (a schematic of the module would be ideal as i have no idea which pin is which)would I be correct that the feed is on the two small plugs on the SAM(in the middle), or am I simply looking at a replacement unit and coding? Grateful for any advice. Thanks.
TL;DR
Vito 2019 daytime running light fault
Swansea
United Kingdom
Other
If other, please explain
Industrial maintenance electrician
Vito SAM fault-help!
Auto Electrician Forum
Thread Tags
spantheman,
