J
jude kennefick
Can anyone help. I have measured the Voc of a pv array at the DC isolator. I get 400 V and the array should measure 450. The Voc on the back of each panel says 37.5 but when tested with a volt meter each panel is reading about 33 which x12 would be about 400v. Does anyone know how accurate this measurement and panel specifications should be. The Isc measures correctly for the whole string array. The panels are risen 250.
