oscar21
Nearly Esteemed
Why is this still a thing, just done a quick calculation with the TLC volt drop calculator and if its a non lighting circuit the recommended size is 6mm but if there is lighting its saying 10mm. Quite a cost difference.
I get this in the olden days when there were filament lights that would go dim if there wasn't enough voltage or the fluorescent would start strobeing on and off but in today's modern world its all LED lighting and whereas 230v was necessary to light a filament lamp an LED one will work with a little as 3V. Obviously it needs more than 3V for the electonics to work but you get my gist I hope, look on any switch mode power supply and it will usually state a voltage range of something like 100V-230V it will work with.
Isn't it about time this was update to recognise LED lights which they themselves say we must use now.
