volt drop query | on ElectriciansForums
Discuss volt drop query in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
zone77
Barrow
When doing a volt drop calc for a sub board, is the max volt drop 5%(11.5v) ( the sub board feeds lighting and power circuits) or is it reduced to 3% (6.9v):confused:
Does it not matter if its for public or commercial use, or am I confused?.
Just looked in BRB and it says
Public lighting 3% other 5%
Private 6% other 8%
Ah and just reading your post agian I see your point I would go with 5%.
If the sub-main is feeding lighting circuits, the the max VD from the origin to the end of the lighting circuit fed from the sub-main DB is 3%.
VD is calculated from the origin of an installation in this case the house so you must include the sub-main as part of the lighting circuit.
This is from the ECA.....
Answer by the ECA: The overall voltage drop limit is 3% (6.9V) single-phase, if the sub-main is feeding lighting circuits.
Zone 77 it dosnt matter where it is. f its from the public supply thw max volt drop from Origin is
lighting 3%
power 5%
When its designed you will find distribution cables may be oversizes so less volt drop so it can be allowed for on the final circuits.
Reply to volt drop query in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
