Hi,
I was calculating volt drop today using xlpe armoured cable, 3 core, single phase. Table 4E4A pg 373. I am using 3 core cable but on single phase, so i would assume column 3 for single phase. I was told by the tech helpline although the cable is being used for single phase that column 4 should still be used as it is the number of cores that is the factor. Can anyone tell me why?
Cheers
Cheers
