volt drop | on ElectriciansForums
Discuss volt drop in the Australia area at ElectriciansForums.net
J
james king
hi all i have been to collage today and we did a bit on volt drop. can some one plase help explain this to me? does this mean on a long run if the cable is not big enuf it will loose volts? eg. 221V?
The amount of volt drop depends what is being supplied. If you know what is specifically being supplied and the spec for the machine has a better tolerance for voltage drop then it could be OK. The 5% rule is for when you don't know whats going to be connected - eg. on a ring main.
Volt drop has nothing to do with tripping breakers.
it was in my local newspaper recently that someone connected a 10KW shower on a 6mm cable, lady was having a shower it switched off half way, she came out to her room to get changed, to her surprise the fire man put out the fire on the roof. the 6mm cable got hot, melted and started buring the insulation.
Reply to volt drop in the Australia area at ElectriciansForums.net
There are two reasons for a fuse/mcb they are: 1) fault conditions - which must exist always, and be capable of operating for all points on the...
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
