volt drop | on ElectriciansForums
Discuss volt drop in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
G
gordysolar
I have a 4mm armour feeding a inverter 22m from board
i worked out vd= resistance per metrex2 xImpp x length which was
0.0046x 2x8.04x22 =1.627
Would this be volt drop in volts or % volt drop?
Reply to volt drop in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
If it is TT then you can use the armour of any of them as CPC but will almost certainly need an up-front delay RCD at the sub-main feed point to...
Hi Mike, Floating Neutral. I'm really over simplifying below, but using generators as an analogy is possibly easier to understand. In a large 3...
