Volt sensing relay calculation | on ElectriciansForums
Discuss Volt sensing relay calculation in the Auto Electrician Forum area at ElectriciansForums.net
Prague
Hello,
pls do no kill me for being this stupid (i am a videographer in nature :), and i need to make an order before my electrician returns from hospital...
I want to add leisure batt to my 1987 VW t3 Caravelle along with volt sensing relay and i cant figure out how to calculate the system:
My current setup:
start batt: 75Amph
leisure: 115 Amp
alternator: 65 Amp
my Qs:
VSR: how do i calculate the neccesary amperage of VSR for my setup? I plan to buy 140Amp, is that not overkill? Does it depend on the capacity of leisure battery and its current drawing when charging? How much does it draw (max) or what is the factor
Wire: Based on what do you calculate its size from start bat to VSR and from VSR to leisure? Also leisure?
Fuses: Based on what do you calculate its sizes on both sides? On the size of the wire?
Thank you pretty much.
petr
Hi,i would strongly advise you not to bother with what is effectively,an idea from the 50's :)
I would get a Dc to DC charge controller,current limited,to suit both your alternator output,and size of leisure battery.
This time of the year,is the busiest,for this exact issue....i may start using the old "....i'm in hospital..." meself :kissing:
Reply to Volt sensing relay calculation in the Auto Electrician Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
