volt sticks | on ElectriciansForums
Discuss volt sticks in the UK Electrical Forum area at ElectriciansForums.net
G
gas man
Hi folks,i Admin over at the plumbing forum,quick question regarding volt sticks,in this case a Fluke brand,now i fault find boilers so am very conversant with a multi meter ,however i use a volt stick to check boiler cases and pipework,on checking the spec on the fluke they go down to 100v,as we know it takes less than 100v to kill you so to my mind volt sticks for what i intend to use one for are pointless,how could i safely test pipework or metal work ?
Seems british gas engineers have to use them as a policy???? noticed the engineer at my dads check all the pipes and frame with his before removing the boiler cover.
British Gas engineers (term used lightly) Jacks of all trades masters of none.
Seems a bit paranoid to me, the boiler should be earthed via cpc and bonding, so very unlikely to be 'live', unless wired up by a plumber. Hey hoe, suppose 'once bitten, twice shy'.
Reply to volt sticks in the UK Electrical Forum area at ElectriciansForums.net
