Voltage drop calc | on ElectriciansForums
Discuss Voltage drop calc in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
googong
can anyone tell me if this is a correct way of thinking
i have 6 Cleaners outlets off a !6a rcd, total run length is 55m
6mm feed to first point is 30m would give me voltage drop of .78% (using half the breaker load according to exception 1 on page 163 of as 3000:2018)
then run a 2.5mm for the remaining 25m giving me a voltage drop of 1.56% (same exception)
total voltage drop of 2.34% ( i need to be under 3 for this installation)
my main question being is it acceptable to break gauge considering the breaker protects the 2.5mm cable as i cant seem to find it in the rule book
in assume you mean a 16A MCB with RCD protection or RCBO. fine as long as the breaker is sized according to the smallest cable on the circuit.
Reply to Voltage drop calc in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
