pablopablo
hello. i need to run power to a cabin that is 350 feet from the service pole in our driveway. the problem is voltage drop. the service pole is 150 feet from the transformer so total run is 500 feet.
is it possible for a diy'er to purchase a small transformer that would bring the voltage up? (i cant find any online)
current plan is to run 6/3 uf-b underground and only wire 2- 15 amp breakers. according to the charts the voltage drop with limited amp draw should be ok.
is this my best bet or is there a better way. We don't need a lot of power up there but 30 amps is about the minimum. any advice is appreciated.
