Hi all,
I've got a job to do regarding an outside supply to a summer house. The easiest route is to pick power up from a car porch. This small board is fed from the house on 2.5mm, which is approx 15m from the main board. Unfortunately the cable is under a driveway and simply installing a new cable for the intended extra supply is not a simple task.
My question is; When calculating voltage drop, do the calculations still work out correctly, if there are two different cables involved? i.e. from 2.5mm t&e to SWA
The summer house is approx 75m from the car porch consumer unit, and if you were to install a cable from the car porch, assuming approx 1 kW power usage, it is possible to 'get away with' 2.5mm, and although there is not a great deal of expected load, this is still a bit too close.
Thanks for your time in advance,
Stuart
Stuart
