voltage drop. | on ElectriciansForums
Discuss voltage drop. in the Talk Electrician area at ElectriciansForums.net
R
Robo
6.9 v for lighting
11.5 for a socket.
So my question is to calculate the size of a supply cable to a building that had lighting power heating for example. What figure would i use for voltage drop.
Is there a wxtra safe rule of thumb method ppl use?
id use the 11.5v mate. its not just sockets its everything other than lights. to the best of my limited knowledge the vd limits are because light fittings some times have voltage sensitive equipment.
6.9 v for lighting
11.5 for a socket.
If the sub main has both lighting and power as final circuits then you need to use the figure of 6.9V or 3%. This has to be the maximum volt drop from the origin to the last point on the lighting circuit.
Voltage drop is monitored to ensure that loads are not deprived of too much of their operating voltage due to cable resistance.
Each final circuit will be treated independently, whilst distribution circuits may need further consideration.
Reply to voltage drop. in the Talk Electrician area at ElectriciansForums.net
The cable is way undersized. If the voltage drop is detrimental to the installation I would make a mention of it as volt drop generally is not...
As you have actually measured the cold resistance (R1 + Rn = 0.15) then you have the voltage drop at the expected current (60A) so you can compute...
