Voltage drop?? | on ElectriciansForums
Discuss Voltage drop?? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
N
Newsome3
Hi
Just a quick one does anyone know were you can get those voltage drop kits ( like the one used on diy SOS about size of a consumer unit) and if so how much they are?
Also what's it roughly save the coustomer per year??
[ElectriciansForums.net] Voltage drop??
voltage drop kit!! make sure you have to hands on it when it drops!
V phase do these they said it would save around 175 quid a year and cost in the region of 250 to 300 I looked into these awhile ago and there were limitations if I remember correctly any load exceeding 6-8 amps would bypass the device, there is a thread on this forum dicussing
Anyone fitted any?
Know if many other are asking for them installing or is it just like this client the odd ones who watched diy SOS?
Reply to Voltage drop?? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
That looks like a Metrel display (I have one), they have a permanent 3 wire display that measures the three combinations so I would say that’s a...
Hello Ric2013, MJPD29 and westward 10. I have a multimeter that I tested the voltage with and before I open the socket up I use a plug in tester...
