Discuss Voltage indicator in the UK Electrical Forum area at ElectriciansForums.net
I know which one I’d rather trust !because they are not reliable. they can pick up stray voltages. sometimes even pushing one back into arse pocket activates them. useful as an indicator,but never trust one. think of them as gypsies.
Fair enoughnever trust either. 1 is misleading and the others are thieving barstewards.
That is worst nightmare situation.all i can say, without a 4 page essay, about my experience with the *******s is that all my wordly goods were stolen/destroyed, and my home destroyed all for the sake of scrap metal. police "had insufficient evidence", after catching them red-handed.
I know, I have a good one of them, just happens to be annoying the mrs earlier and found out thisSomething like this should be your starting point if you want to avoid death by electrocution, etc:
https://www.toolstation.com/tis-voltage-tester/p11032
Is that an FCU with cable exiting front?Just wondering why a voltage indicator pen picks up voltage about 30mm away from a FCU but has to almost touch a socket or cable to indicate ?
home was not just broken into. it was totally destroyed, as in a write off.That is worst nightmare situation.
I got me a armourguard for the van but having you’re home broke in to is a next level of ----ing scum
No just a switchIs that an FCU with cable exiting front?
Generally they work on electric field, and that depends on the line conductor's exposure which may be much higher in an FCU with cable.
Reply to Voltage indicator in the UK Electrical Forum area at ElectriciansForums.net
