Voltage on cpc | on ElectriciansForums
Discuss Voltage on cpc in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
L
Lakelandsparky
Hi all, 1st post. Called to a cottage that was previously an art gallery. Customer said track lighting is causing MCB to trip. Wants them taken out & replaced with pendants. Tried testing system & couldn't get to the bottom of it - Lights all over the place, borrowed neutrals from ring main, switched neutrals, sockets on lighting circuit and an external light that I couldn't find a switch or a JB for. A proper piecemeal, DIY job. Recomended that circuit be disconnected and, to save chasing a stone wall, take the new lights from the kitchen which is on a seperate circuit and had been OK. Test on new intstall OK for continuity, polarity and IR, but when energised have got 70v e-n.
I know, should have tested the kitchen circuit 1st, but has anyone got any ideas what may be causing this - another borrowed neutral?
Reply to Voltage on cpc in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
