Voltage on disconnected cable | on ElectriciansForums
Discuss Voltage on disconnected cable in the UK Electrical Forum area at ElectriciansForums.net
SSE
I think I may be going mad...job I was at today there was a strip light needing replaced, were 3 feeds & neutrals and a feed & switch wire at it. Was sure I marked everything ok but as there are ceiling panels going on before the light goes back on I thought I’d do a quick check, turned light switch on & volt stick buzzed, turned it off & still buzzed. Took readings with it on & got the usual 230v L & N, L & E & 0v N & E. Then turned it off & was getting 60V between L & N and L & E & still 0v between neutral & earth. So...I disconnected the cable & still there’s voltage on it?!?! It’s literally one twin & earth cable that’s being used as a feed & switch from light to light switch. Any ideas?!
[automerge]1568391103[/automerge]
Should have says the L I’m testing is the Live returning from the switch.
Dead good those volt sticks, saved me from the deadly hole punch more than once I can tell you...
[ElectriciansForums.net] Voltage on disconnected cable
Suppose what I really need to know is there any way to get rid of it & if not is it safe to leave in?
Option 1
Terminate each end correctly in an enclosure
That way any induced voltage is safely contained.
Option 2
Remove cable and place in skip,
Should solve the problem.
Option 3
Bond all cores of said cable to something that is connected to earth.
Reply to Voltage on disconnected cable in the UK Electrical Forum area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
