A client of ours are having an 800kva optimiser installed presently.
So its got me thinking, as being as its basically another transformer (dare i say an isolating transformer? although i stand to be corrected!), will this effect the existing Zs values throughtout the installation? Rather like having a UPS in line.
Whenever i test circuits through a UPS the Zs values are higher than in mains bypass, so will the Optimiser cause the same effect?
Any thoughts folks?
yep should do , so the voltage at the far end would need to be compensated to make sure it wasnt below the minimum
west brom
Voltage optimisation
silver surfer,
hadleigh sparks,
