Voltage optimizers any good? | Page 2 | on ElectriciansForums
Discuss Voltage optimizers any good? in the UK Electrical Forum area at ElectriciansForums.net
london
Hi.
Are they any good and how do they work? Do they lower the voltage across the board? If so what about appliances that use more than 220v?
Spynage
I have one installed without it I had 258v come through the sockets and with it I get 220v, I've had it since 2015 I've had no problems with it at all.
That is a use-case where they make sense, although 258V is out of the ESQCR range of +10%/-6% on the nominal 230V (rule 27.3b) so it should be corrected anyway:
How was this measured though? I wouldn't trust simple meters as the sine wave is often distorted by harmonics and the rms calculation might be inaccurate because of it, I assumed if it was out of tolerance ukpn would sort it. Do you have solar and was the voltage causing an issue?
I don't Have solar just a two bed terrace house in town built in the 1800s
Reply to Voltage optimizers any good? in the UK Electrical Forum area at ElectriciansForums.net
these are usually MOV’s metal oxide varistors or sometime spark gaps , these change there resistance with voltage,im fairly sure the lower voltage...
View: https://www.youtube.com/watch?v=glsg2HpWyok
