A
abnjim6
I am installing ceiling fan and when the ceiling wires (two) are tested for the presence of AC voltage and the wall switch is OFF, I read 50 VAC. When switched on the VAC reading is 117 VAC.
I am using a T5-600 Fluke multi-tester in the "V" position.
Should I continue with this installation and risk a shock?
Why does this tester read 50 VAC when the wall switch is in the OFF position?
Thank you.
James
Thank you.
James
