Voltage regulation problem | on ElectriciansForums
Discuss Voltage regulation problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
K
Kimba
I live in Zimbabwe where they don't regulate the voltage. I checked the mains as i noticed a lot of equipment getting overly hot. It has been reading between 350 and 320 volts, when the regulation here is 220 to 240.
Is there a voltage regulator that i can install onto my mains power that will prevent the high voltage spikes from the grid?
Do you have a link for one of these pls? What is their max input voltage?
We did some work in Zim a few years ago. The supply there is atrocious. The systems we installed were fairly low power single phase and we ended up selling the customer a ferro-resonant UPS which did the trick. The one we sourced was made in SA by Power Man Linky
We couldn't find a supplier or manufacturer in Zim at the time so this might be your best bet.
there is- voltage regulation to drop it down if needed
there must be a mistake as your senstive equipment would be fried
Well we did lose a couple mobile phones. Also the touch screens on Ipads and laptop touch pads get all jittery when plugged in.
So, if i'm talking to an electrician here, what do i need to tell him in order to get him to address the voltage regulation?
Reply to Voltage regulation problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If any appliance has a filter or surge protection device, you will have a device that can pass a small current between the L and E or the N and E...
As above, check the whole cable run and look for damage or any junction boxes that might have trouble inside them. Water getting in is a common...
