Voltage regulator which regulates voltage coming our of a DC Generator | on ElectriciansForums
Discuss Voltage regulator which regulates voltage coming our of a DC Generator in the DIY Electrical Advice area at ElectriciansForums.net
Turkey
I need a strong voltage regulator that is used to regulate the voltages coming out of a continuous DC generator. Four poles of high current currents that connect with the thermometer to output a 24 volt voltage to the load. Control by magnetic coil files controlled by an automatic voltage regulator is input 24 volts and output to magnet files with an 8 amp amp Sorry used in the field of old armor
Hi E - I understand you need a voltage regulator, but not much more. Can you give more info? Machine type, rating plate, pics ?
Reply to Voltage regulator which regulates voltage coming our of a DC Generator in the DIY Electrical Advice area at ElectriciansForums.net
As above, check the whole cable run and look for damage or any junction boxes that might have trouble inside them. Water getting in is a common...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
