Voltage tester, am i thinking about this too much? | on ElectriciansForums
Discuss Voltage tester, am i thinking about this too much? in the Electrical Tools and Products area at ElectriciansForums.net
stranded
Hi all, possibly a stupid question, but input from professionals would be appreciated.
Im looking to buy my first voltage tester, (probably fluke) and have been looking at a few.
I understand there are ones with a self test function, or without then you buy a proving unit with it.
My thought is, can you rely on the self test function itself inside the unit, or are you better to go with a proving unit then you know for sure that you are testing it properly?
Any ideas?
Cheers,
Mike.
i wouldn't bother with a proving unit. test on the incomer which is still live after isolating.
True on domestic may be. But on industrial switch gear this may not be the case also accessing a live terminal just to prove your device would be frowned upon under a permit . We have a proving unit for such times but in the real world it hardly used by any of us. Mostly for witness testing and the nic man
2 units can be duff, unlikely but possible, proving unit might be incorrect aswell, but where do you stop. I trust proving my tester off the live side.
I see what you mean. I personally would have a proving unit too..couldn't you test a proving unit with a multimeter? or do they not work like that?
Using a proving unit is fail safe if done correctly. ie voltage tester should prove voltage everytime it is connected to proving unit. If it does not then either the proving unit or the voltage tester is at fault but regardless of which you would not continue.
unless, of course, the neon screwdriver says it's OK. :joker:
Thanks, thats true i suppose. Its either one of the other. Going to get a proving unit in that case. Thanks!
Reply to Voltage tester, am i thinking about this too much? in the Electrical Tools and Products area at ElectriciansForums.net
Hi all, The electrical network in my house (Antwerp, BE) is quite old and consists of two phases of about 140 volts. This gives me approximately...
