Vulnerable Equipment | on ElectriciansForums
Discuss Vulnerable Equipment in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
L
Learning Sparky
Hey all,
Just quickly, can anyone identify Four items of vulnerable equipment you may find in a domestic installation?
Can anyone suggest a reason why it is important to 'Clean out' a panel before testing?
I have many reasons, but the more i think of them the more i think there wrong lol
Assuming you mean brush out /remove deberis?? if so Dust shavings and especialy swarf can cause all sorts of guff Iv seen a subpanel almost blow off the wall all due to a bit of swarf and a dodgy earth
Hi Learning Sparky,
I guess cleaning out a panel could be to remove potential danger prior to testing (risk of shorts) and to facilitate identifying any visual defects hidden by obstructions. This would obviously be done after safe isolation.
Hope this helps,
Best wishes
Rex
Reply to Vulnerable Equipment in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Don't need to read again the picture tells me what I need. BTW your a bit touchy about solar, it's old hat these days 🤣 and a waste of money
I use theses very regularly doing 12 monthly DB inspections, a great bit of kit and easy to use
