Vw electrical vacuum control valve n75 - Ohm values | on ElectriciansForums
Discuss Vw electrical vacuum control valve n75 - Ohm values in the Auto Electrician Forum area at ElectriciansForums.net
SejoH 21
Bosnia
What is a correct Ohms value for n75 valve on vw 1.9 TDI, 96kw engine? I have like 16 Ohms but if I am not misunderstood on spec it says more than that. Does it mean my valve has malfunction? I checked almost everything else but my car still has delayed boost.
Don't have a TDI or a diesel for that matter but I vaguely remember checking it for a friend a few years ago and I think that (16 ohms) sounds about right. That valve gets pulses (PCM) of power to change/keep it in the same position for the required boost. If you google it you should get plenty of hints re testing etc.
Reply to Vw electrical vacuum control valve n75 - Ohm values in the Auto Electrician Forum area at ElectriciansForums.net
I unmounted the intrument cluster and the pins was fine also everything OK with it.
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
5K
