M
mattP1981
Hi, I have a 2003 lt35 that I only recently purchased.
the issue is with the indicators;
hazards are working fine
indicating right everything is fine
indicating left the dash light flashes quickly like when a bulb has gone although, then it slows right down, externally nothing but the noise on dash isn't normal, it's a sporadic clicking.
Possibly it could be the relay? And if so where can I locate this please, otherwise any ideas on what it might be?
thanks in advance
Hi dude,when the hazards are on,are all the lamps functioning ok? Check they are the correct wattage etc.
The clicking should be coming from the fuse board,handbook or forum will find flasher relay.
Check hazard switch is allowing individual n/s and o/s circuits to enable,next on the list would be indicator stalk assembly.
Never discount issues such as this,being no more than an incorrect type/wattage of lamp being fitted...
Hi, thanks very much for your help. All tried but to no avail - new indicator stalk in the post, let's hope that fixes it
thanks very much
VW LT35 2003 Indicator issue
Auto Electrician Forum
Thread Tags
mattP1981,
mattP1981,
