W2D1 - Do I need one? | on ElectriciansForums
Discuss W2D1 - Do I need one? in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Moley
Supporter
Pontypridd, S.Wales
Well, Week 2, Day 1.
Been relaxing in our chalet near Minehead, thinking about life and what do do when I retire. I had planned on quiting at the end of the year but looking at the woodwork on the chalet that needs to be replaced it looks like I'll be working another year to pay for it.
Anyway, one of the toys I really fancy getting myself for retirement is a 3D printer but where do you start? Should I buy a cheap one just to see what I think or spend a lot more and then find I don't use it? I would like somthing with a pretty high resolution but they are dearer. So, time to start looking around. But where do you look? Shopping online you cant see the results but theres not many places where you can go to get advice and actually look at the things. Oh well, still got some time to ponder over it.
We have been through this debate at my local branch of the Men's Shed charity. It always seems to be the case that if you buy enrty-level gear you end up upgrading. We now have a laser cutter, a 3D printer and a CNC machine and it's clear that these need to be at least the level we have, which is reasonably high.
Maybe if you have a branch near you, you could pop in and enquire and get a demo and some hands-on advice too.
Reply to W2D1 - Do I need one? in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
You’re quite right… the charger is in the car…. The “charge point” is screwed to the wall. And just to be pendantic, “solar” means anything to do...
    • Winner
Thanks mate for the advice, this is just what I was looking for. I think I’ll have to put some thought into the domestic route due to the NVQ and...
I did my NVQ a couple of years back now and as I was a sole trader as a mate, I was my employer, so they just let me sign both bits
Your primary concern here is the service wire being #8 aluminum, which, as you mentioned, is typically rated for 40 amps. For a 100 amp panel or...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
