Wago 6mm/1.5mm problems | Page 2 | on ElectriciansForums
Discuss Wago 6mm/1.5mm problems in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
leicester
Anyone had any issues getting 6mm into the 0.5mm-6mm wago's?
It's a real struggle getting the conductors into the terminals but the biggest problem is, when 2x6mm are in, a 1.5mm goes in and just falls back out again. The levers feel real stiff.
It's not a comfortable fit. This is a 3 way wago
I'd be interested to see a picture of this. Im going to presume its a private job because it definetly wouldnt be accepted in a lighting column on a public road
No its within a university. Dont see what the problem is. The SWA are too low in tbe column to make into the cutout but just enough room to make off into a wiska box. The 1.5mm ho7 flex is about 500mm max in length, just enough to reach the cutout which sits above the wiska box.
Both SWA banjo'd together external to the wiska box.
Reply to Wago 6mm/1.5mm problems in the UK Electrical Forum area at ElectriciansForums.net
https://sravivarman.com/technical-articles/parallel-operation-of-thyristors/ Series resistor, or bigger series resistor, needed?
