M
martysparky
Got some Wago's through the other day.
thought I would try and terminate a loop-in in a Wago box taking a feed out for another light, above ceiling connections?
prob is 4 connections at each connector plus the switch live using 3x 5 lever and 1x 2 lever for s/l.
meaning you can only fit 7levers in each side if the box.
could you do as 1st pick or is that pushing it.
Edit
Would that fail intended use as the termination is not located in the termination block receptacle?
Yeah the push fit connectors can get much more terminations in housing.
Any thoughts would be appreciated.
Edit
