wago din rail conectors | on ElectriciansForums
Discuss wago din rail conectors in the UK Electrical Forum area at ElectriciansForums.net
davek
Hi all
I have been looking at a consumer unit change today, and feel I may have to extend the cable due to little slack in the old c/u. Have price up the topjob s but coming out quite expensive, any alternates.
Regards
Dave
In line splice push connectors are neater
[ElectriciansForums.net] wago din rail conectors
Looks tatty with push connectors though, and may want to use it for next assessment. Working out a £38 with delivery for 6 set L N E 42a then need get a box and rail
depends how big you want it but i use these
https://www.wagobox.com/shop/topjob-din-rail-mounted-terminals/din-rail-accessories/dre-5-din-rail-enclosure.html
https://www.wagobox.com/dre-1-din-rail-enclosure.html
wago 862 will do without din rail and you get 3 terminals in one... they 32A rated, but you will struggle to get anything bigger than 2.5mm in there.
if you need something cheaper than wago on din rail then weidmuller or phoenix may do the job, have a look on cpc or rs sites.
Hi Guys
Thanks for your input. think customer will just have to stand the cost, will use the 2006 Series (41A)
for all but he shower. but why does the earth have three ports @ 2 quid
The wago earth connectors also earth to the din rail so be warned for testing. I usually use a normal wago connector for the earth so I can test from the CU.
use normal din rail connectors.
the idea behind the earth terminals connecting to the din rail is for use with the screen in control cables etc.
if your just extending then you dont want to use earth connectors
Reply to wago din rail conectors in the UK Electrical Forum area at ElectriciansForums.net
Having all neutrals commoned on outgoing cables would be problematic where more than one RCD is present or where such protection is afforded...
7K
nicebutdim
N
If you were staying in the house I'd say get them moved with you doing the chasing and plastering. You'll probably be better at plastering than me...
Sockets will probably be ok on one, a little inconvenient in the event of a fault though, I'd probably like a 7th rcbo in. Wonder if hes linked...
6K
suffolkspark
I've just been reading the data sheet. I think the main issue is that the documented IP rating is IP10, so it makes no pretence of offering basic...
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
