Wagobox | on ElectriciansForums
Discuss Wagobox in the Electrical Tools and Products area at ElectriciansForums.net
I
Irmschur
Hi, just woundering what people think about the Wagobox compared to a normal Jbox?
i have received my free wago box and i think there quality just what i have been looking for....i hae been useing the helecon connectors for a while now but found it hard to find a good enclosure for them..........as for tools the black and decker scorpian saw is a must for cutting floor boards
i have received my free wago box and i think there quality just what i have been looking for....i have been useing the helecon connectors for a while now but found it hard to find a good enclosure for them..........as for tools the black and decker scorpian saw is a must for cutting floor boards
Just recieved my free sample today and will be placing an order on Monday........they are the "Mutts Nuts".
Well rapit to assemble while remaining easy enough to pull apart for testing too. :D
Started using Wagos about a year ago, tried a few & now have full range, more expensive than JBs but you save so much time. Don't bother with kits though, just get your own box. Lighting connectors are great when your up the top of a ladder holding chandalier, one end push fits to solid core & cage end prsses to hold stranded. Wago boxes are a must but note that whilst you can get Wagos & boxes direct from 'Wagobox', they are separate companies so you can't get boxes from 'Wago' (bit of bad blood there).
Had a quick look at the lighting connectors, they look great!
So, for your "normal" pendant, I will need 3 pole connector( lever type) for the commons and cpc's
2 pole plus flex connection for the neutral side and single pole plus flex connection for the live side?
Obviously I haven't seen or used these before.
Have I sussed it correctly or am I missing something?
Where is the best place to buy em?
Thanks Gerry
Reply to Wagobox in the Electrical Tools and Products area at ElectriciansForums.net
Apparently so, I’ve copied and pasted below. Octopus Energy, named by the Renewable Energy Association (REA) as “the company that has done the...
Hi I am soon to take the AM2. A friend of mine who just took, said the following items are prefilled in the test schedule. Is it true? - Type...
