- Joined
- Dec 13, 2008
- Messages
- 105
- Reaction score
- 16
Hi all,
I have a theory that I want to put to the test, a customer/chum has some wall lights in the lounge, been there for years no problem, now however one side blows a bulb within 10 minutes of the lights being turned on, I have checked the wiring as far as possible and it all seems to be OK, but, interestingly this started happening shortly after they had cavity wall insulation put in, and, co-incidentally, there is a line of holes on the outside wall that pretty much corresponds to where the wire would be running, so putting 2 and 2 together my suspicion is that they have 'nicked' the wire going to the wall light. I would be grateful if anyone has any other ideas. I'm assuming that all I can do is try and pull a new wire through when I take out the old one.
For info I am Part P qualified but not rich in experience as you can probably tell.
Thanks for any help
Down2earth.
Thanks for any help
Down2earth.
