Wall lights everywhere but not a single ceiling light | on ElectriciansForums
Discuss Wall lights everywhere but not a single ceiling light in the Australia area at ElectriciansForums.net
swifters
I have a customer who wants all the wall lights removed and ceiling lights installed. It's a 80's build town house. Plasterboard walls and ceilings e.t.c. The lighting circuit is RCD protected.
Problem is I don't know why they have not installed any ceiling lights apart from the one's in the bathroom? If all goes well and I can get to the JB without taking the ceilings down and/or chipboard floor then great, but I have visions of not being able to locate the JB's and coming unstuck.
Anyone else out there had the same problem? It's wall lights in all 3 bedrooms, the kitchen, the lounge, the hallways....Everywhere!
Am I best to advise them to keep with the wall lights?
Are you just assuming there are jbs ?, because loop in feed and neutrals at switches may be more likely
You are going to have to access the under the boards so whats the problem, unless you joint the wall light cable and fish them centre in which case you wont need to find any jbs
Yes, I'm hoping they are spider wired, the house is on three floors, couldnt gain access to loft (only about 2-3ft void, almost flat roof) and I imagine T&G chipboard floors too. If they are looped then I think I'll forget it.
If they are looped I suppose you have to leave all connections you make accessible anyway which would kind of defeat the object as customer wants plane walls.
Permanent joints !
These are new items on the market and such it is not clear that they meet the requirements for a maintenance free joint
They would have to be mounted in an appropriate enclosure
After this year the enclosure would need to have MF stamped on it
Ratched crimper and suitable enclosure is by far the better option
Malcolm may be ancient but he sure is on the ball when it comes to quick reactions with the keyboard
[ElectriciansForums.net] Wall lights everywhere but not a single ceiling light
Reply to Wall lights everywhere but not a single ceiling light in the Australia area at ElectriciansForums.net
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
