Wall Mounted Laser Leve | on ElectriciansForums
Discuss Wall Mounted Laser Leve in the Electrical Tools and Products area at ElectriciansForums.net
T
Tin
I have a job coming up and Im looking into getting a wall mounted laser level as I have a load of p-clipping to do and with the laser level, the job would be easy.
Does anyone know of a decent laser level? Something easy to use?
Cheers
Tin :)
I assume you are wanting to put a line accross or up the wall to follow while clipping? If so you do not need a wall mounted laser. The stanley CLL
[ElectriciansForums.net] Wall Mounted Laser Leve
projects horizontal or vertical lines (or both together) and is affordable at around ÂŁ80 with the mounting pole.
Hope this helps
Thanks eskimo39.
Im looking for a laser that I can attach to the wall that I want to clip on, saves me pinging a chalk line.
Any Ideas?
Try this one : Bosch PLL 5 DIY Laser Spirit Level
However the CLL would do the job fine, I always use it when installing trunking/conduit etc, I just set it up opposite where I am working and it beams a line accrossthe room onto the wall I am working on, same as a chalk line without the mess.
The bosch one in the above link comes with a mount to clip it on to the wall but is limited in functions that the CLL can do.
Hope this helps
Just taken a picture of my CLL on horizontal and vertical lines (you can choose just one if prefered)
Reply to Wall Mounted Laser Leve in the Electrical Tools and Products area at ElectriciansForums.net
They also come with a hefty price tag and have fewer functions than the cheaper ones. Mine has been battered about for the last few years and has...
