If someone made a request to you, to install a new double socket that would be supplying power to a tumble dryer along a circuit that does not go into a location where those types of device are usually located, like a kitchen or utility room, but goes instead from the hallway into the living room, would you think it appropriate to install it by simply splicing off another socket? Would you reasonably expect the results of such a fitting for the dryer to overload and burst the fuse over and over again? (the socket was installed a year ago, but I can only assume it was not suitable for the job intended due to the dryer being new at that time and it words perfectly ok in the kitchen now.)
I ask because I had an electrical company fit a socket and now they are trying to charge me to come out in order to 'investigate' the problem.
