B
brightspark11
I have noticed that professional decorators cut out the wallpaper around switches and sockets so that the edge of the paper can be seen around the fitting. I have always removed the fitting, wallpapered then trimmed the paper to the edge of the back box and replaced the fitting, this way looks much better. Does anyone know if there are any regulations for or against this practice.
In the past decorators used to loosen the socket / switch screws and tuck the paper under.
They wouldn't do it nowadays H & S would require them to have the socket isolated.
Also the same if using emulsion.
No regs lol.
If I were to pay a so called decorator to work in my house and he trimmed the wall paper flush to any socket or switch I'd turf him out. It laziness with them nowadays.
Same when people have a plasterer round to over skim some walls, they never drop the front of the sockets or switches.
Had this the other week, plaster had skimmed the kitchen and there were 2 switches and a socket still screwed back. Actually mentioned it to him and came out with the old 'it doesn't say electrician on my van so I don't loosen them off'.
So whilst he stood and watched I loosened them off, taking a nice patch of skim off from around the edges of said socket and switches. I turned and said back to him 'It doesn't say plasterer on the side of my van, so you'd best get it patched up!'
You should of seen his face, priceless!
plasteres and decoratorsa re bad enough, but when tilers tile a socket/switch in, that is the pitts!
Especially if it's the thin flat plate type. The number of times i have told a tiler "make sure no part of your tile covers the metal box".
When i come back for 2nd fix, can't get socket to fit because of tiles hanging over edge of metal box!
i was thinking more of tilers concreting the faceplate in by tiling round it, rather than lifting it off to tile behind. the no. of times i've had to break tiles to fix a faULT OR REPLACE A SOCKET ... JEEZ.
Last time this happened it was out with the grinder and diamond blade. The joiner went mad as the newly fitted kitchen was a little dusty after i'd finished.
Did give him the option to either get the tiler back to sort, he could sort it or i'd sort it, which i did. Think he thought i was going to be faffing around with the small tile saw he gave me, yeah right!
After the problems i have had with plasterers in the past i have now come to the conclusion after much deliberation they are all brain dead.
Saw something in PE mag a while ago, think it was called 'youzie box' or something. It was an insert to put in boxes to stop plasterers 'hiding' them. Doubt they worked coz the plas'ers prob remove them so they have a 'clean' wall.
The small amount of additional time spent at first fix dressing the cables and fitting the Yoozyboxes, is repaid ten-fold at the second fix, no more digging plaster out of the back boxes or cursing the plaster because he's sliced the insulation of the cables with his trowel. My plasteres love them because it's quicker for them to work to an edge, without the possibility of snagging cable or filling back boxes.
Yoozybox by HLH Enterprises - Domestic Elecrical Problems Solved
Not all bad. One cleaned out all boxes for
me a month ago.
You're quire right. One lad I will always and only ever use when its me getting the plasterer in always cleans out every box. But that must be why hes charges a little more than the numpty that doesn't
Not sure the word "professional" should be in this sentence, surely it should be substituted for "lazy"
i had a problem with one once, i had a go at him because he filled half my boxes with plaster so i couldnt fix my cpc to back box or get my 3.5mm screws in without a chisel. his relpy was "i should put a cover over them so it wouldnt get dirty"
next time a put some plastic bags and tape across so the lazy --- could work easy, he then plastered straight over my switches and sockets and said "he thought id made a mistake and wanted them filled over as he couldnt see any cables"
pay peanuts get monkeys :59:
Had one on a site years ago,a stud wall with about 8 points in it,the plasterer kept drylining over the lot and it was a pain to locate the points,so I told site agent if it happened again the wall was coming down,went back on monday and the plasterer had been in over the weekend,same trick I went to the van and got the sledgehammer while the other lad went to site forman.I went through 3 houses before they could stop me!never saw the plasterer after that,but my boxes never got covered over any more lol:clap:
Onr idiot plasterer seemed to follow me around from site to site for a while. His favourite trick was to completely fill each and every box he could, and if he could he would start to polish his filth.
I finally got the better of him when I walked into a room he had just done, having played his usual trick, so I dragged my fingers all over his newly plastered wall looking for my boxes. It looked like artex when I was finished.
He never filled any of my boxes after that:)
Wallpaper behind sockets and light switches
brightspark11,
trev,
