Want to ad sub panel to outside house main disconnect panel | on ElectriciansForums
Discuss Want to ad sub panel to outside house main disconnect panel in the UK Electrical Forum area at ElectriciansForums.net
Arrowhead
USA
m new here and want to learn. I have a project I want to tackle but if it is above my means I will call an electrician. I have a main disconnect panel on the outside of my house. I want to add from it a sub panel to feed my pool and shed and also an outlet. I did some searching but still not sure what panel box to buy. I think I understand the sub panel will need a neutral and ground bar. Thank you all.
  • [ElectriciansForums.net] Want to ad sub panel to outside house main disconnect panel
Reply to Want to ad sub panel to outside house main disconnect panel in the UK Electrical Forum area at ElectriciansForums.net
There is nothing inherently wrong with this part of the layout. There is another option that you may want to consider. Those supply conductors...
Yes you will need to install # 4 wiring times 4 for your 2 hots, 1 neutral and 1 equipment ground. As for keeping the grounds and neutrals...
