I have an old home that was purchased 35 years ago, all wiring is original from that time and it still has the old fusebox installed the type that uses actual fusewire.
I am wanting to have this replaced with a modern CU.
I am not a qualified electrician but more than capable of replacing sockets and light fittings as they really do need doing since these were all fitted at least 35 years ago, all cabling is PVC there is no old lead or rubber insulated cables as far as I'm aware if I replace the sockets and light fittings would it then just be a matter of passing an EICR test and having the old fusebox replaced with a modern CU by a local electrician providing the existing cabling is satisfactory or would there likely be further work needed.
