Wash machine fault | on ElectriciansForums
Discuss Wash machine fault in the Australia area at ElectriciansForums.net
A
andyww
Hi
Can anyone tell me how to test a washing machine pump for faults (tripping RCD) - I've tested the machine via the flex for ins res (all ok) and there is no continuity between live/earth or neutral/earth.
I don't have any knowledge of appliances - not even sure what the pump would look like?
Andy
Dont whatever you do put a megger on it,theres electronics in there!
Have a look on uk whitegoods where there pictures of pumps etc.There should be spade connectors on the pump and a simple resistance test will let you know if its ok.What makes you think its the pump?
Reply to Wash machine fault in the Australia area at ElectriciansForums.net
Very technical :D
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
