Washing Machine broken wire. | on ElectriciansForums
Discuss Washing Machine broken wire. in the DIY Electrical Advice area at ElectriciansForums.net
Mansfield
Hi. I'd be grateful if anyone can offer me some friendly advice please.
My washer stopped spinning and I discovered the fault to be a broken wire on the motor connector block on the washer side connector.
Here's a picture.[ElectriciansForums.net] Washing Machine broken wire.
I took the motor out a while ago and cut the tiewrap that secured the cable but I made the mistake of not re-securing it. I think this caused the break due to excessive vibration. I think it's safest to assume the remaining wires are likely damaged also.
There's enough slack to trim the wires back and make the good the connections. I can't see how to remove the wires from the block though. This seems the obvious solution if it's doable.
Failing that, could I remove the connector and replace it with a suitable terminal block/connector?
Or, should I buy a replacement harness and replace that section?
Or something else?
Thanks for taking the time to read this and also many thanks in advance if you're able to offer me advice.
Cheers
You can get tools which slide in either the front or the back of the block to release the individual connectors.
I imagine on that block, there should be a little cut out on the front where you should be able to poke a thin screwdriver down to release the connector.
A photo showing the front of the connector block would be good.
Reactions: DPG
As above, there will be a way of removing the female pin from the connector. Take a pic of the front, back and the other side of the connector and post them up.
Reactions: DPG
and a pic of the other half of the connector. if that has accessible wiring then wagos may be your easiest option.
Reactions: DPG
Hi again. First and foremost I'd like to say thanks for taking the time. It's very much appreciated.
Here are some better images of the connector numbered 1 to 5.
I've ordered a tool kit off Amazon similar to the one suggested that's available on Prime so should get it tomorrow. I've looked at the connector again and I'm still at loss. I'd be grateful for an idiots guide on how these tools manipulate this connector please.
(telectrix)It's difficult to get an image of the other connector without flipping the washer but I do know the wires are accessible. I've had a look at the Wagos connectors on screwfix. I'm guessing the 24A would be more than adequate?
Thanks again.
Cheers
Hmm. Looks like you might have to dismantle the connector body if you want to access the contacts. Likely to be some sort of snap fit to prise open. I also think that they may be IDCs, insulation displacement contacts, similar to Krone or Scotchlok.
If you're not confident, then replacing the wiring loom may be your best bet.
You also get a 10A plug together connector strip you could use to replace the entire plug. Not sure where it's available in the UK, maybe try e-bay...
Rather than mess about with the existing connector I would remove the connectors completely and, as mentioned above, replace with wagos or similar. Will be a more reliable fix in the long term, especially if you aren't used to working with those sorts of connectors.
agree. get some 2 port wago 221 type connectors. cut off existing plugs, 1 wire at a time and connect each pair.
Reactions: DPG
add to above. these wagos, if you never used before, are easily release able, and designed to make a good connection on fine stranded flex. just strip the wire in accordance with wago instructions, 10mm - 12mm. and 24 A is well adequate.
And send us a photo of it when you've done it! We promise not to be too critical
I have a feeling that the connector block plugs into the back of the motor, not into another connector block.
Seems to be quite a lot of black dust, as if from smoke.
Reply to Washing Machine broken wire. in the DIY Electrical Advice area at ElectriciansForums.net
I would agree that the motor is by far the best part to replace. if it is powered and not turning then it is broken. Keep it simple!
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
