Washing machine drain hose. plumbing advice | on ElectriciansForums
Discuss Washing machine drain hose. plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Washing machine drain hose. Hi
I'm unsure what is acceptable when routing the drain hose from a washing machine.
Is the loop shown in the picture acceptable?
Additionally, the rubber end to the drain hose almost closes off the 40mm opening of the stand pipe. I know that a gap must be present. Looking at the hose, the last 150mm of the hose appears to be slightly different. Can this be cut off to allow the hose to go into the standpipe and give an air gap, instead of it fully closing of the opening like the rubber end does.
Many thanks in advance
Washing machine drain hose. to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Washing machine drain hose. plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Washing machine drain hose glued!! Hi, Thanks for looking. I am getting a new washing machine who will install, disconnect, recycle it, etc as...
seamybee
T
Water appearing in washing machine when run kitchen taps Hi there! When I run hot or cold kitchen tap, clean transparent water slowly appears in...
T
