W
whazza22
Hey all,
I pat tested my washing machine at home yesterday and it's failing the insulation resistance test, giving a reading of 0.87 Mohm.
After some investigating, I found that by unplugging the drain outlet pump, the insulation resistance reading is now >199 Mohm. Therefore the pump is causing the failure of pat test.
Does this mean that the pump is due to fail in the near future or do they normally cause problems with pat tests?
