Washing Machine Tripping RCD? | on ElectriciansForums
Discuss Washing Machine Tripping RCD? in the UK Electrical Forum area at ElectriciansForums.net
V
vincef
Hi,
I changed a 20amp flex outlet plate, which fed a commercial washing machine, in a nusery, for a 1G SW socket with built in 30ma RCD protection, as none of the building/Installation had RCD proctection. The faulty commercial wash machine was being replaced with a domestic one with a 13a 3pin plug, hence why the 1G socket was installled. Was called back to day because the NEW highly electronic domestic washing machine with Digital screen kept tripping the 1G socket with built in 30ma RCD protection keeps tripping the rcd. Tested RCD with tester & another load no probs, NEW washing machine works well when plugged in to another circuit with out RCD protection, Think this could be caused by the washing machine nuisance tripping? Any ideas?
maybe you could chaage different plug type(commando socket) so no1 else could plug any other item in with standard 1363 pulgtop... obviously this electronic is using earth as functional.
ps. im only small fish in big pond so maybe wait for more suitable answer
Some times trips straight away when switched on & some times stays in then trips in spinning cycle, Do not understand how my own wash mach at home works ok on protected 30ma splitboard, but the one at nursery trips 1g buit in rcd socket, any one have more info? how can you RCD protect this type of wash mach in future?
Vincef
trust me its the appliance, a cable inside is caught causing the problem.
i rewired inlaws house 6 yrs ago installed a new CU with rcd when washer was on, it tripped rcd. inlaw said it never happened before!! i said yeh but you didnt have an rcd facility before either!!
just to confirm things i had a washer guy 10 doors away who plugged his computer into it to confirm my thoughts.
Reply to Washing Machine Tripping RCD? in the UK Electrical Forum area at ElectriciansForums.net
You may still have a problem with earth leakage though, it could be that the Samsung has less leakage than the Bosch ones. If you do get a random...
As you said in #9 get an electrician involved. The information you are giving is not clear as you do not understand what is being asked which...
