Washing machine trips 32 amp mcb intermittently | on ElectriciansForums
Discuss Washing machine trips 32 amp mcb intermittently in the UK Electrical Forum area at ElectriciansForums.net
E
egginyourface
Called to a property today. Customer said that kitchen ring circuit trpped whilst washing machine was half way through cycle. Tested the circuit with my insulation resistance tester and all was fine.
Tested the appliance itself and found dead short between live / earth and 0.26 between neutral and earth.
I told the customer the appliance is at fault and needs to be replaced.
Couple of things I don't understand are is it true washing machines leak to earth sometimes and what is the reading. Also why wasn't the plug top fuse popping.
Tanks
Plug the machine in switch on and IR test the circuit L-E show customer the reading, unplug it and test it again, show customer the reading, this is his how I had to prove to a nursery owner that his dishwasher was knackered and tripping his RCD , when the engineer finally came he confirmed the motor windings were shot.
Sometimes also the faults don't appear until the motor is under load, so a dead IR test won't show a fault
Tanks
leak to earth yes....how much...depends...
The fuse board didn't have an rcd. 32 amp breaker was tripping. The reason I'm asking this is I had a similar call out recently and tested the washing machine and told the customer washing machine had gone faulty with live/ earth fault.
H called out washing machine repair man who told them there was nothing wrong with it...
I had a washer dryer that tripped the rcbo intermittently.
I found the fault when it went up in flames one day - it was the heater for the dryer function full of fluff. Bloody stupid design !!!
Tanks
Are you sure its taking out the MCB?
Reply to Washing machine trips 32 amp mcb intermittently in the UK Electrical Forum area at ElectriciansForums.net
You may still have a problem with earth leakage though, it could be that the Samsung has less leakage than the Bosch ones. If you do get a random...
