Waste pipes above ceiling in new extension Discussion Thread | on ElectriciansForums
Discuss Waste pipes above ceiling in new extension Discussion Thread in the Plumbers Forums area at ElectriciansForums.net
This is an RSS feed of thread: Waste pipes above ceiling in new extension
Content of the thread: Hi guys
I have expressed an opinion on this waste plumbing which is by a builder on an extension to a terraced house belonging to a relative. My opinion has not been received well so what do we think? The new black pipes will soon disappear under a pitched roof brought across from the left. The narrow pipe, apparently 40mm drains just a sink upstairs. There is a vertical 110 mm going down in a 300mm gap between the 2 houses.
Thanks for your opinions!
Waste pipes above ceiling in new extension to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Waste pipes above ceiling in new extension Discussion Thread in the Plumbers Forums area at ElectriciansForums.net
T
What plumbing tape is recommended for a copper waste water pipe Hi there, We have a leaking waste water pipe which our washing machine, boiler and...
Tellie
T
Help joining waste pipe to shower waste please Hi, just a quick question about the standard way you connect 40mm waste pipe to the outlet of this...
dameo220
