Water appearing in washing machine when run kitchen taps Hi there!
When I run hot or cold kitchen tap, clean transparent water slowly appears in washing machine - this water smells - have to scoop it out! Not sure if issue is installation - washing machine is sited not far from sink (live in flat and kitchen small). Here is a picture of the piping work under my sink - any ideas why the water starts to fill in washing machine when taps are on? Could it be the inlet or drain hose? When I do a wash in machine there is no issue with water draining out. The issue is when I run the taps which for some reason results in water filling in machine.
Thank you!
Water appearing in washing machine when run kitchen taps to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Thank you!
