T
TPES
Hey all what do you think to this..
Ive had a call out to 2 faulty lights in 2 different bedrooms.
Bedroom 1, the lights work, but when the customer changes the lamps they blow very quickly.. (so he says)
Bedroom 2, the lights dont work at all, the customer has tried new lamps but nothing.
All cores are black.
Further investigation in bedroom 2 revealed the circuits are installed using MIMS cable. The feed is at the fitting with switch wires down to the switch.
I removed the switch to find no voltage at all on either core. After time belling out the cores i determined what was what.
When i removed the light fitting i found alot of water damage to the cores, This had been caused to the flat above being flooded over 6 months ago. See the attached photos
In the photo you will see..
Feed in / N in
Feed out / N out
COM down to switch
Switch Live
From what i have figured there is no voltage at the switch as the COM down to the switch has been damaged/broken.
I tested this by linking the Switch live into the Perm feed, this will give me voltage at the switch, but when the switch is switched there is no voltage back up at the light. Only one of the cores seems to be intact.
I need to write a report on this of the dangers and whats needs to be done to rectify the fault. what would you write?
Has anyone come across this before? What do you think?
I'm sure it will need a re-wire
Feed in / N in
Feed out / N out
COM down to switch
Switch Live
