disco
Hi Everyone New Here - I have a TNS installation and I am unable to find a stopcock inside the house to attach my 10mm earth from the CU to there is a stopcock in a ratbox outside the front door. Is it alright for me to attach the earth to what I "think" is the first upturn of copper out of the concete floor (which happens to be the kitchen tap. I do not know the required distance from the stopcock that the earth is supposed to be attached to.
2nd question - Is there anything that states that a combi boiler on a 6amp fuse at the CU rated down to a 3amp sf/spur CANNOT also have a permanent feed and neutral taken before the sf/spur go on to feed a pull switch shaver light in a bathroom as long as it is clearly marked at the CU?
THX
THX
